Old 12-05-2011, 04:09 PM   #1
Bradbutlernc
Title: Banned
Default Kenwood KL 888X home tower 5 way speaker only playing woofer
I have 4 of these in my shop so i can have a little music while working, ran off a big 4 channel pioneer rack amp. 1 of the speakers has quit playing everything, only the woofer plays the lower ranges so it has no mids/highs or anything above 200 hz really. Ive taken it apart and verified everything is hooked up, all the speakers and tweeters test good, and nothing is burnt on the crossover or potentiometer. Other than that, i dont know much about these speakers or the crossover networks inside them. Can someone offer some help? Heres a video of a guy who has 2 in his house i found for reference.
http://www.youtube.com/watch?v=y7h5Z8A8VlA
Old 12-05-2011, 04:50 PM   #2
Anubis
Anubis's Avatar
Default Re: Kenwood KL 888X home tower 5 way speaker only playing woofer
Is there a circuit breaker for the mid and high drivers? Disconnect the drivers from the cross over and check for impedance with a mulitmeter. If they're open, there shot. Remember that dirty power (a clipped waveform) will fry high freq drivers fast. Know when your amp is reaching its limit. My Adcom GFA565 mono blocks have distortion alert indicators for this reason.
Old 12-05-2011, 04:59 PM   #3
Bradbutlernc
Title: Banned
All the coils are in spec, every thing tests good no rub etc. Is there a way to bypass the pots on the speakers? They have a "soft /normal /clear" 3 way switch with 4 wires going into the crossover board. I cant see a circuit breaker unless its on the board, and then i dont really know what im looking at. I will get some pics of the board. I usually play the reciever off a pioneer 7800mp which puts out real clean power through the RCAs, and never turned it up very loud.
Old 12-05-2011, 07:16 PM   #4
FDWheelMan
FDWheelMan's Avatar
Photos: 16  Users Photo Gallery
Send a message via Yahoo to FDWheelMan
Have you tried the speakers on a different channel or a different tuner?
I'm more into vintage systems... I am running an older Sony STR-V5 on a set of older Kenwood speakers. The volume is incredible and the music is crisp clear and inviting. However, from time to time, the right channel drifts out slightly. Wiggle the volume knob and it comes back... Annoying, but when I took it to the "Best Shop in Town" I paid $150 for the idiot to run some glass cleaner over the case and give it back to me. Pissed me off. Never again! That was one of the things he was supposed to fix.
If all your speakers show being within specs, then chances are it might not be the speakers.
78 Holiday 88 - 350/350 Olds - Daily Servant & Autocross lawn dart - 133 RWHP/208 Ft/lbs Torque.
90 Mustang Coupe - 2.3/T5 - 24 Hours of LeMons Race Car
01 Mustang Bullitt - The car that was built to do all three but sits in the garage, collecting dust.
Old 12-05-2011, 09:09 PM   #5
Bradbutlernc
Title: Banned
It is the speaker. Ive swapped them on alot of different recievers. 3 work fine but the 1 is giving me trouble. All the speakers coils are in spec, and both read 6 ohms at the binding posts like theyre supposed to. I may try swapping the pots out and see if the problem could be there.
Old 12-07-2011, 03:28 PM   #6
analogkid455
analogkid455's Avatar
Hey I have an Adcom also with clipping lights. Mine is the 60 w.p.c. two channel amp. I use it for my satellite speakers and I use a 600 watt bridged Parasound amp for the sub. I get about 115 dB without clipping.
Erik
1987 442 Blue T-Top 1 of 1916 bone stock 250k miles and counting!
1974 Omega 468 BBO 3620# 11.85 @ 112 MPH 1.62 60ft 87 octane
http://www.cardomain.com/ride/829130
Do you take a shower and only wash one ass cheek and leave the other one filthy?
NICE JOB GM Way to cut your own nuts off!
Old 12-07-2011, 03:41 PM   #7
Bradbutlernc
Title: Banned
Well the problem was the crossover. I ended up taking the crossovers out of two of them and replacing all the drivers except the 16" woofer. Made my own cheap crossovers using capacitors and wired pairs in series then parallel for a final load of 8 ohms at the reciever. Actually sounds better than it did before
