Old 10-11-2010, 12:25 PM   #1
olds307 and 403
olds307 and 403's Avatar
Default Torque converter stall speed?
Okay, I have a generic 2000-2600 stall converter. I tried the one foot on gas and brake and would maybe get 2000 before wheel spin. Someone mentioned that was a poor way to measure stall. I went out and hammered the gas from a stop, no brakes. The tach went up to 2400 rpm and starting spinning and kept spinning past 4000 rpm. Repeated and again instantly went up to 2400. Is my stall speed 2400 rpm?
1988 CSC, Ported #6, 9.5 to 1 Olds 350 .483/.508, 2004R, 3.42
Old 10-11-2010, 12:43 PM   #2
Default Re: Torque converter stall speed?
Your converter flash point is 2400rpm. Its probably a bit less than that, you would need to get the car to hook up completely. Once the tires break loose, you cant expect any of the readings(rpm,mph) to be correct
It should be very close to your "stall" speed. About the only way to check your stall rpm would be to install a trans-brake and find out
Also, if you change the engine combonation, the stall speed of the converter will most likely change, depending on the torque curve of the reworked motor
Old 10-12-2010, 07:25 AM   #3
analogkid455
analogkid455's Avatar
X2
Erik
1987 442 Blue T-Top 1 of 1916 bone stock 250k miles and counting!
1974 Omega 468 BBO 3620# 11.85 @ 112 MPH 1.62 60ft 87 octane
http://www.cardomain.com/ride/829130
Do you take a shower and only wash one ass cheek and leave the other one filthy?
NICE JOB GM Way to cut your own nuts off!
Old 10-12-2010, 08:25 AM   #4
olds307 and 403
Thank you. I figured with the torque this motor puts down, there no way I would be at the bottom of the scale. I would bet my flash point is right near peak torque. I have a chance at a 3000 stall lock up converter for cheap. He says it is tight on the street, usually stalls at around my flash point. But when he pushed it, would hit 3000 rpm. Would I gain anything at the track with my mild combo? Lose anything?
Old 10-12-2010, 01:05 PM   #5
Also things like grip (tire width) and vehicle weight come into play here too....
If you got wide meats and a heavy car, your existing converter will flash higher before the car moves or you start to burn out.
Old 10-12-2010, 06:12 PM   #6
There is no way of knowing how this other converter will re-act in your car with out installing it and driving the car.
Does you current trans have lock-up, I dont believe the two(lock-up/non-lock-up) are interchangeable, but Im no trans expert.
Old 10-12-2010, 07:18 PM   #7
olds307 and 403
Both lock up. P245/60R14 tires in back and car weighs nearly 3700 pounds. I will probably leave the converter as is, considering it is stalling about where I want it.
