Old 09-22-2010, 07:53 PM   #1
gbodyfan
gbodyfan's Avatar
Default th 400 in a g body
I tried searching but couldnt find anything. I was wondering what all is involved with putting a th400 in a g body cutlass? I have a 86 cutlass and was thinking of putting a 455 and th400 in it but was wondering what all is entailed with it.
Mainly speedo cable and drive shaft small stuff like that. I know the drive shaft will have to be made i have a couple of old drive shafts laying around might see if i can make somthing out of them. What do i need to do for a speedo will the stock cable and gear work or will i have to change it.
I am planning on using manifolds but will prob build a dual exhuast cross member so thats all taken care of. Motor mounts prob 307 mounts.
Also is there any difference in the transmissions i dont know the ways to identify them but i have 4 of them 2 short shaft and 2 long shaft. i was wondering if there was any way to tell what they came out of. I pulled 1 short shaft out of a 77 caddy with 425 i think it was the original. 1 of the long shafts is out of a 74 88 but i doubt that is what it is for (it has junkyard writing). I was planning on using the short shaft out of the caddy cause i know its good.
Eric
Save tires. Take corners on 2 wheels.
"Some men are Baptist others Catholic my father was an Oldsmobile man."
Old 09-22-2010, 08:03 PM   #2
Evan
Evan's Avatar
Default Re: th 400 in a g body
its quite a bit of work, considering you could just get a beefed up th350 and put it right in if u had a th200 and if you had r4, i think just the th200 crossmember is all you need to put th350 in it...maybe a drive shaft fr0m a th-200 car also? help me guys. i do know 350 is direct replacement for th200,ive done it
My Rides:
1985 Cutlass: Hurst Olds Tribute
'69 350 SBO,# 5 heads, A4 intake, Holley 650cfm, Comp XE-268 cam, headers, TH-350, 2.73 posi, 79 Hurst/Olds Dual Gate shifter, 1983-84 Hurst/Olds SSIII wheels spoiler, & hood.
1978 Ford F250 4x4 :
400 engine, C6 transmission
1965 Chevy C-10 Stepside
327 3 spd
Old 09-22-2010, 08:49 PM   #3
70455
The 455 will bolt in pretty easy. To keep your A/C you will need to use all the brackets and pulleys off the the 307 and you will need to use the water pump for the 307.
The transmission will bolt in if you use the crossmember for 200R4.
Old 09-23-2010, 03:38 AM   #4
87Salon
87Salon's Avatar
Title: Tornado dodger
If you need a driveshaft let me know. I bought one a few years back from someone who put less than 1k miles on it and ended up selling my project. Still just collecting dust in the garage
It's for a long-tail TH400 to 7.5" rear, I could get a true measurement if you need it.
Oldsless for the moment......
Old 09-23-2010, 10:22 AM   #5
sleepin cruiser
sleepin cruiser's Avatar
If you have a short tail th400 its not that bad of a swap at all. Ths speedo cable is the same, the crossmember is the same as a 2004R, the driveshaft shouldnt need to be modified just have the large yoke put on. The kick down switch is easy to hook up all cars have the spot for it, and the only big pain is bending the cooling lines to fit right. O and you need a vacume line.
rides:
86 442 Parts Car
87 Cutlass Supreme Brougham.
307/200C / 72 350/2004R 3.23 14.5@94 2.1 60ft
(8.5" 3:73 posi 14.3@96 2.1 60ft)
88 Cutlass Supreme Classic Brougham. SOLD!!
Was: 307/2004R, now: 72 350/Th350 16.1@85 mph
88 Custom Cruiser.
73- 350/Th400
91 honda civic Lx.
67 Chevy Impala 4dr hardtop Family owned since 1967
Orig 327/Th400, going to be 327/700R4 or 2004R
Old 09-23-2010, 01:05 PM   #6
joe_padavano
joe_padavano's Avatar
Even a short tail TH400 is about an inch longer than a 200-4R. Using the stock driveshaft runs the risk of bottoming the yoke and damaging either the trans or the rear end.
Joe Padavano
62 F-85 Deluxe wagon (the NV desert car)
62 F-85 Deluxe wagon (the San Jose, CA car)
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
Old 09-23-2010, 04:33 PM   #7
gbodyfan
gbodyfan's Avatar
Thanks for the info. Just wanted to make sure i didnt have to switch the speedo cable. I got some steel and a welder i was gonna build a crossmember cause i dont have any extra 2004r ones laying around. Do they make different plastic gears for making the speedo correct?
The drive shaft its prob gonna be trailer it to the driveline shop and say make one.
Evan as far as the trans this car its gonna be for fun not racing and i have the th400 dont have any extra th350 or 2004r. Im just gonna bolt it to a stock 455 and go just to get the parts out of the garage.
Eric
