#1 |
Title: Proud Olds Owner
Rebuilt Olds 403 With 7a Heads Edelbrock Cam, Double Roller Timing Chain, Intake Carb!!! Runs Fine At Idle Except For When You Take Off Its Bogs Down And Gas Comes Back Out Of The Carb??? Has A New Carb On It!!! Got The Timing Set Rite I Believe What Is Going On Here Somebody Please Help!! Some People Are Telling Me I Should Have Degreed The Cam??? Is This A Timing Issue Or What??
#2 |
Sounds like fuel psi is to high get a reading on what your fuel PSI is when you are doing that. or all so make sure you float is set right.
1981 Chevy monte carlo 396 BBC .060 over 9.7:1 voodoo 60203, 3:42 Posi GTA rims Upcoming 700R4 swap 8.61 1/8 mile on street tires
#3 |
![]() Daily Driver - 355 cid, UltraDyne .485/.485, 217/221 cam, Performer RPM intake, 750 cfm QuadraJet, HEI, Heddman Headers, TH350/Hughes 2500 stall, 3.23 limited slip, BFG 245-60-14s on SSII wheels |
#4 |
edelbrock!!! i have tried 2 other carbs also just to make sure the carb was not the problem and they all did the same thing
#5 |
I agree....sounds like float issue, or fuel pressure. Since you've tried other carbs, I'm leaning toward fuel pressure being too high. Get a gauge on there.
If a company advertises something as "indestructible", Trust me, I'm the guy you want testing it. iiiquaziii@yahoo.com, iiiquaziii on AIM/iiiquaziii on Yahoo messenger and gmail and gtalk. http://www.facebook.com/#!/profile.p...00001623773081 in facebook.
#6 |
X3 on fule supply sounds like high line presure. What do you have for a pump? If you are using hp pump you will need a regulator.
#7 |
im using a stock fuel pump
#8 |
what plugs should i use with 7A 350 heads and what should they be gap at???
#9 |
Check the timing while you are at it.
#10 |
Good point Run to Rund. Yes check your timing.What dist do you have and what have you done to it. When you have a problem like this you should go back and check out your whole ignition system and fule system.
#11 |
i have check my dist and timing i have it set at 12 degree at idle and 32 i believe overall!!! i have messed with the timing so much it runs great at idle its when u take off it goes flat and bogs down!!! btw i have a knew dist also!
#12 |
Throw 4 more degrees at it.
1988 CSC 424 ci SBO stroker coming soon........ 1994 c***y 4x4 Olds 350 TBI, rebuilt 4L60E, 3.73 gov lock 2010 Challenger SE, Stone White, leather, 18" wheels 2000 Dodge Dakota Sport Club Cab 4x4,3.9 v6, auto, 3.92 no slip |
#13 |
What brand distributor is it?
#14 |
a kmj performance hei!!! other words some cheap stuff!!!
#15 |
Is that a after market off shore unit from China. I would start there if it is not a quality dist.
#16 |
HEI with 12º initial advance? That sound very low unless there is a recurve kit in it.
I would suggest you verify that total timing number before you go any further. The numbers just don't seem right for an HEI, with or without a recurve kit.
#17 |
My stock weight HEI, I have 15 base and 36 total. I have one light, one medium spring. The other Autolite reman HEI has weird big weights and 23 base is needed to get 36 total. They do vary. Get your timing set where it needs to be and #86 Autolite plugs should be what you need.
| Thread Tools | |
| Rate This Thread | |
