Old 08-23-2010, 03:11 PM   #1
CUTTY
Default torque converter for with 350 trans
what's the stock torque converter for with 350 trans..? an is there any numbers on them or look up an see what you have
1980cutlass calais 307-th350 stock
Old 08-23-2010, 04:07 PM   #2
Default Re: torque converter for with 350 trans
"Stock" really depends upon the specific factory application, as in different TH350s could have different stall RPM depending upon the vehicle type, weight, engine's RPM range, etc. The stock converter behind a '69 W-31 would be very different than the stock converter behind a '77 Delta 88.
Old 08-24-2010, 10:38 AM   #3
cdvana
Title: Olds in the Blood
When buying a converter I found this company... which has a very responsive tech line and so far has been a solid converter.
http://www.eatmyshift.com/
