Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
Old 05-27-2010, 07:33 PM   #1
mkube396
mkube396's Avatar
Title: critical mass
Send a message via AIM to mkube396
Default th350 kick down not working
^^^^^^^ what would make this happen? shift kit?
I have looked under the pan every thing looked fine with the linkage, cable is working I can feel it spring back. When I have it at WOT cable is pulled all the way.
1981 Chevy monte carlo 396 BBC .060 over 9.7:1 voodoo 60203,
3:42 Posi GTA rims
Upcoming 700R4 swap
8.61 1/8 mile on street tires
Old 05-28-2010, 10:58 AM   #2
Default Re: th350 kick down not working
Are you certain that the hook on the end of the cable is attached inside the transmission?
Old 05-28-2010, 12:05 PM   #3
mkube396
mkube396's Avatar
yes
3:42 Posi GTA rims
Upcoming 700R4 swap
Old 05-28-2010, 12:21 PM   #4
I thought the TH350 used a vacuum kickdown?
Old 05-28-2010, 12:46 PM   #5
mkube396
mkube396's Avatar
the Vacuum Modulator controls part thrdle up shifting and the cable controles down shifting or "passing gear"
3:42 Posi GTA rims
Upcoming 700R4 swap
Old 05-28-2010, 01:03 PM   #6
Vacuum modulator controls shift firmness and also the upshift points during part throttle shifting. Cable controls kickdown into second gear when jumping to WOT.
My first thought was also that the cable fell off the hook inside the trans, or was siezed, but he says its moving freely and still hooked on.....
So, any other ideas?
Old 05-28-2010, 02:23 PM   #7
From what I remember (it's been a while since I was inside my TH350) the cable hooks to a "lever" inside the trans and the other end of the lever rides against the end of a valve, or a rod that actuates a valve. Maybe the valve is not moving or the passage that it feeds is blocked?
You asked if a shift kit would cause this - did you recently install one? If so, perhaps the spring for that valve is installed incorrectly? I would have to look at my shift kit installation instructions at home to see how everything goes together to see if that is even possible, though.
Downshift gear depends upon RPM (seen at governor, I think). Anyway, downshift is not necessarily to 2nd gear, it can go to 1st if the RPM is below a certain limit. I'm sure you know that, I'm just stating it for others who may not know.
Old 05-28-2010, 03:36 PM   #8
84 H/O
84 H/O's Avatar
Title: Turbo Tard
Send a message via Yahoo to 84 H/O
I'm not that familiar with the 350 trans but did you do anything to the governor lately? Is the kickdown cable pulling the lever the correct amount? I believe the later 350 kickdown cable is adjustable.
Tony
1969 442 convert- 400, 200-4R, 3.73 posi, OAI, every option but cruise and power locks
87 Sunbird GT turbo convt - 13.61 @101, 260 whp/350 wtq. Not bad for only 2 liters huh? Same size as a coke bottle........
2009 Solstice GXP- quick and handles like it's on rails. I love these turbo 4 bangers!
2012 Ford FX4 Ecoboost V6, murdered out and ghetto cool
Old 05-28-2010, 04:48 PM   #9
Brofac
You know, I have a similar issue. I have a TH350 that I had a mechanic put in for me. When I picked it up he said the kick down wasn't working properly. At the time I was too stupid to ask why. I'm sitting in the same boat as you my friend.
Old 05-28-2010, 07:58 PM   #10
mkube396
mkube396's Avatar
I did not do anything to the governor, and i did not recently install a shift kit but there is a kit installed.
quaz when you stop over ill let you feel it may be it isn’t pulling out all the way?? Ill have to compare it to yours. But I know the cable is fine.
3:42 Posi GTA rims
Upcoming 700R4 swap
Old 05-28-2010, 08:27 PM   #11
dan2286
dan2286's Avatar
Originally Posted by mkube396 View Post
quaz when you stop over ill let you feel it may be it isnít pulling out all the way?? Ill have to compare it to yours.
'84 Cutlass
Old 05-28-2010, 09:13 PM   #12
matt69cutlass
Originally Posted by dan2286 View Post
Who wants to bet this ends up in the quotable quotes thread?
Old 05-29-2010, 06:13 AM   #13
mkube396
mkube396's Avatar
o boy...............
3:42 Posi GTA rims
Upcoming 700R4 swap
OldsPower.com © 2012 Herald/Rothe
