Old 11-14-2009, 06:17 PM   #1
franknitti
Default Water Pump NPT Plug????
What size NPT Plug do i get to plug my water pump at the top where the heater hose goes in?
Old 11-14-2009, 07:19 PM   #2
Default Re: Water Pump NPT Plug????
Well, you'll have to have it tapped for a NPT fitting first. So whatever you tap it to will be the size of plug you'll need.
Just guessing looking at my water pump it would need to be a 3/8" NPT at the very least.
Have you thought about just buying a rubber cap and using a hose clamp instead?
Old 11-15-2009, 05:18 AM   #3
kevinkpk
kevinkpk's Avatar
Title: Old age and treachery
I was thinking 1/2", but you can determine that.
Old(s) cars and guys rule!
Old 11-15-2009, 06:42 AM   #4
matt69cutlass
I use a freeze plug. The casting is thin behind the hose fitting, I worried about the metal cracking when I ran a tap thru it.
Old 11-17-2009, 10:38 PM   #5
Run to Rund
Some pumps take 3/8 NPT and others take 1/2 NPT. I have tapped both sizes on different pumps. the only difficulty is removing the pressed in hose fitting. I usually weld a nut to it and use a slide hammer to pull it.
