Old 08-11-2009, 06:47 PM   #1
Gammar
Default How to check gas tank level???
What would be the best way to check your gas tank level when ur gas gauge dont work on a 1981 cutlass?
I know i seen ppl use like a stick to see how much is in the tank on older trucks.
Old 08-11-2009, 07:44 PM   #2
matt69cutlass
Default Re: How to check gas tank level???
does the gauge work at all? Does it read completly full or empty? If I remember correctly the fuel sender wire is tan. With it disconnected the gauge will read full. Ground it and the gauge will read empty. Check the ground, if its not good the gauge wont read correctly. If the ground is good and the gauge works correctly when checking the tan wire you need a sending unit.
Old 08-11-2009, 08:13 PM   #3
Title: They cal me Mellow Yellow
If the gauge/wiring system is f*cked it's easy to check....shove a dowel rod down there and see how far it gets wet. You'll get used to it quick.
If you want to fix the guage, ground it out. The needle should go all the way over.....then ground out the wire by the fuel tank, with the key in the on position. if the needle goes all the way over, the wire to the sender is good. Check the grounds first....its easy.
If the gauge doesn't change when you ground it...either the gauge or the wire is bad....
Old 08-12-2009, 08:27 AM   #4
Title: Stupid should be fatal
Drive it till the car stalls and wont start....then its empty.
Old 08-12-2009, 08:41 AM   #5
Fuel sending wire is pink. At least on the G-body's. Tan would be the oil sender wire.
Old 08-12-2009, 09:02 AM   #6
matt69cutlass
I stand corrected! Doh!! Not sure what I was thinking.
Old 08-12-2009, 01:18 PM   #7
one442
Drove a car like this my entire ownership. Every 100 miles I filled the tank. If I lost track I would push down on the trunk listen for the slosh and fill up ASAP. Worked out fairly well, did make an attempt at fixing it but overall it didn't really bother me.
Phil
http://one442.blogspot.com/
Past rides
Old 08-12-2009, 01:25 PM   #8
87Salon
87Salon's Avatar
Title: Tornado dodger
Been there, done that. That is how I figured out the one on my 86' was stuck, I couldn't figure out how I was getting such good gas mileage
Oldsless for the moment......
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
OldsPower.com © 2012 Herald/Rothe
