Go Back   OldsPower.com > Discussion > Body/Interior/Chassis Repair
Old 08-06-2009, 01:27 PM   #1
dan2286
dan2286's Avatar
Default Lifting body off frame
I have done a search and pretty much know what most people do to lift the body off the frame. I have been reading that most people use the front and rear pinch welds to put the piece of wood to support the body. My question is, what if most of my pinch welds are completely rotted out, especially on the rear quarters? Will I be okay using those areas and just letting them collapse till they stop? I tried using the wheel well area and I have no way of safely supporting it while it is that high. I should be able to make the front work, but the back is my biggest problem right now because of all the rust. Also, will the spare tire well get in the way of the wood that is going to be going across the area?
The body is getting scrapped just so you all know. Damage should not be a problem.
T.I.A.
Edit: Actually, do I just lift up the rear of the car using the pinch welds in front of the rear wheels?
'84 Cutlass
Old 08-06-2009, 04:46 PM   #2
Default Re: Lifting body off frame
Yes, you just need a piece of wood in front of the rear wheel wells to support it. In the rear that is.
Old 08-06-2009, 08:30 PM   #3
J-(Chicago)
J-(Chicago)'s Avatar
You can just use an engine hoist and a chain on the junk body. Just run it through the tail light wire holes. Yank it up and push the chassis out from under it.
Old 08-07-2009, 06:42 AM   #4
Hunter_alexande
Hunter_alexande's Avatar
Title: Wheres the tits?
Or you could do what I did.
When all else fails, throw money at it. That'll fix it.
1986 442 (sold)
1987 Cutlass (sold)
1998 GTP 191k miles and still going strong.
New project ...?
Old 08-09-2009, 03:44 PM   #5
uzl442
uzl442's Avatar
When I took mine off the frame I had 6 or 7 guys help lift the body up. Once we lifted it up we rested it on 55 gallon drums until we got the body where I needed it then we placed it on jack stands.
Current Rides:
1966 Olds 442, back on the frame, finishing metal work on fenders, hood and decklid
Engine: 67' 425 with 385 factory hp
1959 Edsel Ranger 292 automatic, 2 door hardtop, Mist Green/ Seafoam Green Two Tone, should be road worthy this summer
Daily drivers
- 1988 Ford Festiva L, 71,000 miles - cost $100
- 1993 Cutlass Ciera S, 3.3 V6, 93,000 miles
