Old 06-04-2009, 03:47 PM   #1
TheBigO
TheBigO's Avatar
Default Black Electric Holley Pump(Turbo Boost)
Question?
In my Turbocharged BBO I am using a Black Electric Holley Pump with a spring fuel booster.....with the stock (new) factory intake fuel strainer...So my question or questons is...Do you guys removed the stock strainer filter with the Holley Electric pump? Does strainer interfere with Black Electric Holley fuel flow?( I am not running a inline fuel filter....because even the so call high flow filters restrict my BBO fuel demands on low boost!)
Right now I am in the process of installing 255 lph inline Walbro fuel pump(cheap ebay) to assist the black holley pump.....where my so called highflow inline fuel filter used to belong...
http://videos.streetfire.net/video/T...psi_649505.htm
Turbocharged 455 BBO
http://www.streetfire.net/video/turb...nk_1852754.htm
Old 06-04-2009, 06:46 PM   #2
svnt442
svnt442's Avatar
Title: Oldsmobile "Numbskull"
Send a message via Yahoo to svnt442
Default Re: Black Electric Holley Pump(Turbo Boost)
Try this one. There is NO WAY it will restrict your fuel flow.
http://store.summitracing.com/partde...5&autoview=sku
Randy
75 Cutlass S 260 - Junked
76 Cutlass Salon - Wrecked
75 Cutlass - parts car
80 Cutlass Supreme - Sold
70 Cutlass S Post - stripped & junked
72 Cutlass Supreme - stripped & junked
70 442 SOLD..and REPURCHASED!!!!!!!
Old 06-04-2009, 06:57 PM   #3
chromefeet_withbeat
chromefeet_withbeat's Avatar
Title: I have an Olds life
i had that fuel filter (or one very similar too it) to run with my mallory pump which i couldn't use. that filter is so big, it can be mistaken for a fuel pump. i seriously doubt such a filter would restrict your flow considerably
Old 06-04-2009, 10:21 PM   #4
svnt442
svnt442's Avatar
The one you have uses -6 lines. That one has the ability to use 2 -8 lines on both the inlet and outlet. That was why I suggested that one.
Randy
Old 06-05-2009, 04:00 AM   #5
425 Racer
So why a Walbro? Are they something special? Lotsa gph & pressure?
Nick
A small block with big block attitude!!
380 cubes (+ 45)
"Many messages are hidden because olds school is on my ignore list."
Old 06-05-2009, 04:34 AM   #6
Are you sure its not the crappy Holley pump not providing pressure? Personally, that would be the first thing I'd get rid of if you wanted something reliable.
Have you considered converting over to a Grand National fuel tank? For the big horsepower GN guys they have a dual Walbro intake fuel pump setup where one pump runs continuously and the other will turn on and off based on boost pressure.
Old 06-05-2009, 03:49 PM   #7
TheBigO
TheBigO's Avatar
I double check the Black Holley Fuel Pump and had it clean with the rebuild kit a while back....it works great on a Normal Aspirated engine.....it just.. does not give the fuel demands on the psi side to push threw... a so called high flow filter.....I have considered welding a rear sump on the fuel tank one outlet for the black holley fuel pump and one for the Walbro inline fuel pump.
Old 06-05-2009, 06:39 PM   #8
svnt442
svnt442's Avatar
What filter are you having these issues with?
Randy
Old 06-07-2009, 12:25 PM   #9
Anubis
As FE3X Clone eluded to, in the GN and aftermarket fuel injection world Walbro pumps are the shyte because of their flow rates and reliability. I run one in my LT1 powered Z71 and have been very happy with it.
Old 06-07-2009, 08:51 PM   #10
TheBigO
TheBigO's Avatar
Sorry for late responds....I been working on my Olds fuel system.... after work for the last two days......oh boy.....This is embrassing I had my fuel filter backwards
Wow.....I can mod my own Blow through Holley for force induction...but I am unable too install a fuel filter correctly!
This is the link to the filter I bought for my olds.
http://cgi.ebay.com/ebaymotors/NEW-1...4506.m20.l1116
Old 06-07-2009, 09:54 PM   #11
svnt442
svnt442's Avatar
That would do it.
At least you figured it out.
Randy
