Go Back   OldsPower.com > Discussion > Brakes/Suspension/Rear End
Old 05-23-2009, 07:10 AM   #1
olds70supreme
Title: Olds in the Blood
Default G-body / S10 Rear Drum Brake Anchor Pin
Does the anchor pin on a G-body/S10 rear drum brake backing plate have a nut on the backside to secure it to the plate? I am talking about the stud at the top of the backing plate (just above the wheel cylinder). My junkyard backing plates did not have a nut on the backside. Putting the brakes together, however, I am noticing it is really easy for the stud to work its way out of the hole. The stud does have threads, which I am not sure but look like 14mm.
Any help is appreciated.
Old 05-23-2009, 10:52 AM   #2
69hurstolds
69hurstolds's Avatar
Title: Soylent Green Processing Facility Supervisor
Default Re: G-body / S10 Rear Drum Brake Anchor Pin
I just yanked an NOS one out of the box....nope, no nut. There are threads, but it appears it is pressed into a hole and the splines hold it into place, similar to the way a wheel stud is installed. The threaded part should fit into a hole in the axle tube flange. On some models it calls for a nut, but can't remember on the G-bods.
http://www.oldspower.com/photopost/data/500/medium/874423.jpg
If you don't like something, change it. If you can't change it, change your attitude. Don't complain.
Old 05-23-2009, 06:41 PM   #3
Eightupman's Avatar
Title: Parts Haulin Mule
I am pretty sure they are press fit = new backing plates or weld that one in place.
John
Old 05-23-2009, 08:00 PM   #4
outsider_27
outsider_27's Avatar
Send a message via Yahoo to outsider_27
I installed backing plates I bought new, there is a nut to hold that anchor in place. The old ones also had a nut on that anchor.
My lug nuts have more torque than your ricer!
http://www.cardomain.com/id/outsider_27
feedback thread
http://www.oldspower.com/vb/showthread.php?t=42444
