Old 04-28-2009, 08:30 PM   #1
TheBigO
TheBigO's Avatar
Title: Olds in the Blood
Default BBO on Turbo Boost....Video!
Here a sort vid my BBO on low boost....
http://videos.streetfire.net/video/T...psi_649505.htm
If you are member of streetfire.net......please give a comment.....you will not hurt my feelings........but member 69Chevelle454 feelings will be hurt if he does not like your free opinion or he just delete your comment
http://user.streetfire.net/profile/TheBigO.htm
Turbocharged 455 BBO
Old 04-28-2009, 08:37 PM   #2
Seanmay1
Seanmay1's Avatar
Title: I'M THE KING of my own very small world
Default Re: BBO on Turbo Boost....Video!
you should get a video from outside the car so we can here it running, but you have the set up i want lol. Love the car
Cars:
89 Firebird Formula WS6 TPI305/T5 3.45 Posi 9 bolt
K&N filter, airfoil, SFCs, strut tower brace, TB bypass, airbox modified, smog removed, no cat, dynomax catback (junk), WS6 suspension, and a chip
06' GSXR 1000
05' GSXR 600 (track bike)
nitrous is fun on bikes
RIP FREDDIE E. MAY
Originally Posted by 4Speeds4Ever View Post
Dude, bitches come and go. Oldsmobile is forever.
Old 04-28-2009, 08:50 PM   #3
TheBigO
TheBigO's Avatar
I have no air to fuel raito gauge.....so I pull the spark plug one on the left and right head both have a light brown on them.
Old 04-28-2009, 08:53 PM   #4
Seanmay1
Seanmay1's Avatar
http://www.plxdevices.com/wideband.html
I want a wideband 02 from this place, about 270 for the kit
Cars:
06' GSXR 1000
RIP FREDDIE E. MAY
Old 04-28-2009, 08:55 PM   #5
TheBigO
TheBigO's Avatar
$270 bucks.....that amount will pay for the cam and headgaskets I need
Old 04-28-2009, 09:09 PM   #6
Title: Stupid should be fatal
Light tan on the plugs is the desired coloring. Is this a blow thru carb set up, or EFI? It looks like youve done a really nice job of plumbing it and setting everything else up. How do you control max boost, adjustable waste gate?
Heres a plug chart
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
1970 SX W-32
Before Chevy, before Dodge, even before Ford, there was OLDSMOBILE
... 1897-2004
This space for rent
Old 04-28-2009, 09:13 PM   #7
TheBigO
TheBigO's Avatar
Its a Holley 750cfm blowthrough self modd.....I just change the wastegate spring.....I have a 3.36psi, 5psi, 7psi, and a 10psi....all used.... but they work.
Old 04-28-2009, 09:26 PM   #8
SnyperBob
SnyperBob's Avatar
Uh dude, that's a bad ass setup. Do you have a build thread anywhere or a site with more info on your setup with more pictures?
I would like to see more!
Old 04-28-2009, 09:38 PM   #9
TheBigO
TheBigO's Avatar
Most of the info on my setup....you find in streetfire.net....TheBigO profile
Old 04-28-2009, 09:44 PM   #10
Id put the 3 psi spring in it, put good gas in it, make sure you timing is where you want it, and go give it a run. Run it thru all the gears and then pop the plugs out of it and see what the look like. Its how we did it years ago, before the O2 readers became available.
What type of ignition? is it boost refrenced(retards timing under boost)
1970 SX W-32
... 1897-2004
This space for rent
Old 04-28-2009, 09:44 PM   #11
Seanmay1
Seanmay1's Avatar
I thought you had your turbo mounted in the rear of the car? that might have been someone else or did you change it?
Cars:
06' GSXR 1000
RIP FREDDIE E. MAY
Old 04-28-2009, 09:54 PM   #12
TheBigO
TheBigO's Avatar
I use to have it rear mounted.....but its look much cooler.....when you have it upfront and do not have to worry about the electric oil pump giving out.
Old 04-28-2009, 10:01 PM   #13
TheBigO
TheBigO's Avatar
For now....I have a 5psi spring in the wastegate because the 9.5.1CR and stock Fel-pro headgaskets.
The ignition is a HEI pertionx that I already had on the motor...when it was normally aspirated......what I understand...there ok for low boost application...but I guess anything above 7psi...it would be a good idea to upgrade......the fuel boost refrenced is a mallory 4309 with a black electric holley pump with a boost pressure spring.
Old 04-28-2009, 10:25 PM   #14
MSD makes a couple of Boost Referenced Ignition Boxes, you could keep the hei and connect one of these and set it to retard timing when under boost.
Whats you head chamber CC.
1970 SX W-32
... 1897-2004
This space for rent
Old 04-29-2009, 12:40 AM   #15
SnyperBob
SnyperBob's Avatar
I couldn't find much info on your streetfire profile, just this:
455 Olds .30 bore over with rebuilt rods with ARP bots, and std crankshft, 7 qt oil pan, rebuilt GA heads with big block valves, and with mild porting, 4 angle valve job, Edelbrock performer intake with a 750 Holley Double Pumper and big block exhaust maniflods.
turbo exhaust outlet 4" splits into dual 2.25" exhaust with 3" Walker Thrush Welded Mufflers.
I was wondering if you have those pictures that you have slideshow in one of your videos uploaded anywhere? So is your setup all mechanical or whatever? No special computer controlling it? That's amazing!
Do you have any pics or info of your setup when you had it rear-mounted?
Old 04-29-2009, 06:43 AM   #16
TheBigO
TheBigO's Avatar
No promblem.....I will setup a slide show on my profile later on......I used to have one.....but it just disappreaded on me?? And yes...no computer control on a mechinal Holley 750cfm carb engine....its all mechanical.... All the pictures for the rear mounted mod are gone.....there just some things I do not want too remember.
Old 04-29-2009, 07:53 AM   #17
mkube396
mkube396's Avatar
Title: self hater.
Send a message via AIM to mkube396
WoW that is cool!
some times i do feel like i have a crayon in the brain
1981 Chevy monte carlo + Chevy 396 = crazy FUN! 8.616 @ 82.38 Mph in the 8th
like uncle ben says.... "With great power comes great responsibility" Drive Safe
don't be a REV Mechanic you dont need to rev it to the moon to fix it.
2003 impala the driver
1981 Monte Carlo
1991 Oldsmobile Calais "RIP" 130K
1989 Oldsmobile Cutlass Supreme "RIP" 140K
Old 04-29-2009, 03:31 PM   #18
Cutlass84
Cutlass84's Avatar
Title: Cutlass supremecy
Send a message via AIM to Cutlass84
that's awesome man!
I love coheed & cambria but I would like to hear the turbo more!
Old 04-29-2009, 05:31 PM   #19
ODB2
Title: Registered User
Very sweet!
Old 05-13-2009, 02:33 AM   #20
SnyperBob
SnyperBob's Avatar
Post up some pics of your setup! please
Old 05-13-2009, 06:30 PM   #21
BIGJERR
BIGJERR's Avatar
Photos: 21  Users Photo Gallery
Iam thinking grudge race............My 9.1 cat piss gas motor on spray VS Turbo 455 ............
CLICK MY SIGLINE FOR MY ONLINE OLDS STUFF!!!
Your 2010 ALL OLDSMOBILE CAR CALENDARS HERE>
http://www.petersenracing.org/bigjerr/Calendars.html
