Thread Tools Rating: Thread Rating: 10 votes, 5.00 average.
Old 08-24-2008, 08:00 AM   #1
workingspy
Default Power Steerig Pump mounting diagram
Hello, I am having a problem with finding the right way to mount my Power Steering Pump and I will follow tonight will pics if needed. What I have right now is a Power Steering Pump with a two piece bracket, one part screws into the front of the pump and the other flat piece that bolts onto the back and the two mounting screws go threw both brackets to bolt to the block. Now I cannot find a way to actually bolt the whole thing properly to the block, am I missing a bracket piece or is there just something simple that I am missing? Or maybe some one has a diagram of how it is mounted?
Cheers
Evan
Old 08-24-2008, 01:38 PM   #2
joe_padavano
joe_padavano's Avatar
Cheers
Evan
There are actually three parts to the bracket, the front, back, and a third piece that runs from a tab on the front bracket to the front bolt on the exhaust manifold. There should be a stud on the bottom large water pump bolt and a stud on the bottom front cover bolt. There is a third bolt that goes into the side of the block in front of the motor mount. There are also two spacers, one over the bottom stud on the front cover and one (about 3/4" thick) that goes between the bracket and the side of the block.
Joe Padavano
62 F-85 Deluxe wagon (the NV desert car)
62 F-85 Deluxe wagon (the San Jose, CA car)
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
Old 08-24-2008, 01:49 PM   #3
workingspy
Thank you very much and this explains alot, now we will try to find this last piece and see if we can get it to work right. Would you happen to have a pic of the setup or just the third piece, or by chance is it a smaller bent piece with a large circle cut out of it?
Old 08-24-2008, 02:31 PM   #4
69hurstolds
69hurstolds's Avatar
Title: Soylent Green Processing Facility Supervisor
Maybe this can help?
http://www.oldspower.com/photopost/data/500/medium/874423.jpg
If you don't like something, change it. If you can't change it, change your attitude. Don't complain.
Old 08-24-2008, 03:00 PM   #5
workingspy
That is what I am looking for as for diagrams but my bracket is different. The back piece is flat and bolts to the front piece at the bottom and other two bolts pass threw both brackets before they bolt to the motor. I will be home soon and will post a pic of the whole unit.
Old 08-24-2008, 03:55 PM   #6
workingspy
Ok here are two pics of the power steering pump and brackets I am looking to use, hopefully they will help determine what I have. I also have the brackets that came off my 350 that look like the one in the diagram from what I remember but I do not want to use that one. The one I want to use is the one that came with my 455, I want to use this one because it has a nice aluminum front bracket piece. Take a look and see if you anyone can ID this setup. If you can't make the pic out the pump is sandwiched between the two pieces, the bottom of the three bolts is holding the two together and the top two are passing threw both pieces to hold the whole thing to the motor.
Cheers,
Evan
Old 08-25-2008, 08:14 AM   #7
joe_padavano
Did that aluminum bracket come off an Olds motor? I've never seen one like it before.
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
Old 08-26-2008, 09:43 AM   #8
workingspy
That I am not sure but it was sold to me with the olds motor and the pump is the same as the olds 350 one I think. Will the 350 pump bracket work on the 455?
Old 08-26-2008, 10:50 AM   #9
svnt442
svnt442's Avatar
Title: Oldsmobile "Numbskull"
Send a message via Yahoo to svnt442
Yes. The lower dimensions are the same.
Randy
75 Cutlass S 260 - Junked
76 Cutlass Salon - Wrecked
75 Cutlass - parts car
80 Cutlass Supreme - Sold
70 Cutlass S Post - stripped & junked
72 Cutlass Supreme - stripped & junked
70 442 SOLD..and REPURCHASED!..wrecked
Old 08-26-2008, 01:05 PM   #10
joe_padavano
All Saginaw PS pumps are pretty much the same. That looks like it might be a bracket for the Buick V6.
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
Old 08-26-2008, 03:09 PM   #11
workingspy
Interesting
I should have done it before but let me see if I can find a part #, that might be all we need to id it.
Cheers
