08-22-2008, 12:59 PM
#1
Photos: 10
power windows.
ok i got the motor out and all the wires of course are disconnected. when i did this i left the windows open/down  is there an easier way to get power to them rather then taking of the door panels and giving direct power to the motors? i guess what im asking is, does anyone have a picture on what wires under the hood need power to do this since i have tons of access to those.
Faster, faster, faster, until the thrill of speed overcomes the fear of death.
~Hunter S. Thompson
1988 cutlass supreme classic. 1979 olds 403, stock bottom end, holley street dom. intake, #7 heads with 3 angle and bowl ports, 1.7/2.0 ss valves, 224/224 cam, holley 670 street avenger, hooker headers, 2.5" straight to flowmasters, 8.5 rear/ 3.42 gears. Eibach lowering springs in all 4, Umi rear upper and lowers, F41 sway bars.
Nick
08-22-2008, 01:30 PM
#2
Photos: 31
I'm thinking it would actually be easier to hot wire the window motor with a cheap extension cord than trying fo find the proper wire in the firewall connector. Just go from a battery to the power window switch on the driver's side. Or better yet, take out the power window circuit breaker and apply power to one side of that.
Rich
'84 Cutlass Supreme Brougham, T-top, 350/200-4R
'68 Pontiac Tempest Custom, 2-Door Coupe, OHC 250
'73 Pontiac Grandville, 455/400, Donor car
'76 Pontiac Bonneville, 400/400, Das Boot(hooptie)
'99 GMC Sierra, ½ ton, 5.3l w/Hypertech tuning
No Bill of Attainder or ex post facto Law shall be passed.
-Article 1, Section 9, United States Constitution
08-22-2008, 01:39 PM
#3
Photos: 31
Power window C/B is at the top of the fuse block, marked WDO. Power seat C/B is on the lower right... if equipped. You'll need to ground the battery you're using to the car in order to hot wire the windows at the circuit breaker.
Rich
08-22-2008, 01:49 PM
#4
Photos: 10
thanks!
~Hunter S. Thompson
Nick
08-22-2008, 07:10 PM
#5
If the engine harness is still in the vehicle, all you have to do is apply power to one of the two fusible link wires (or both simutaneously) that were attached to the starter......with power to the links and a good ground, turn ignition to on and raise the windows...........As a precaution, make aure the alternator wire is not touching any metal areas........
 He Who Dies With The Most Toys Wins
| Thread Tools |
| Rate This Thread |
