Old 06-20-2008, 09:28 AM   #1
The Stickman
The Stickman's Avatar
Default Oil pressure sending unit location?
I want to put an oil pressure gauge in my 88 Custom Cruiser. But where in the heck is the location for the oil pressure sending unit?
1979 Olds Cutlass Cruiser ChopTop delivery
1984 Olds Rocket 88 Custom(BattleCruiser)Cruiser
1988 Chevy R30 ramp truck with TBI 454.
1992 Audi wagon
1996 Subaru wagon
http://www.oldspower.com/vb/showthre...=battlecruiser
http://the-stickman.tripod.com/index.html
http://www.youtube.com/user/TheStickman
Old 06-20-2008, 09:43 AM   #2
HFX
Assuming you have the 307, on the little firing order ledge behind the waterpump and before the intake manifold off to the drivers side.
Old 06-20-2008, 12:41 PM   #3
Beeterolds's Avatar
Title: Armed and Hammered
Send a message via AIM to Beeterolds Send a message via MSN to Beeterolds Send a message via Yahoo to Beeterolds
right above the water pump..you will see a mechanical mushroom... just below the intake... remove it with the special socket or a set of channel locks. just dont snap it off in the block!
1983 Oldsmobile Cutlass Supreme
02 5.3 V8 LM7 LS1 camshaft, Edelbrock Performer RPM Intake, 750 Q-jet
GN Th2004r D5 Converter
GM 8.5 3.73
Old 06-20-2008, 12:53 PM   #4
442_rocket
442_rocket's Avatar
Title: Oldsmobilin'
All the V8 blocks 65 and newer have the sending unit just to the right of the block casting number. I can post a pic if needed.
1985 442
1980 Cutlass Salon (gone)
1976 Cutlass Supreme (gone)
1973 442 (long gone)
Old 06-20-2008, 01:14 PM   #5
As a side note, dont use the brass or plastic tubing included with most oil pressure guages as they will either brake or burn thru, causing an oil leak that you may not catch in time. Autometer sells pre-assembled -3 braided line, in different lengths, for just this purpose. Spend a little now, save a lot later.
Old 06-20-2008, 01:31 PM   #6
HFX
If you decide you don't want the risk of an oil line at all, they do have electronic sending unit gauges. If figure I can come up with a T for the oil, but I'll need to figure something out for the water. This will come after I finish fixing my lean issue which is causing me to fail on NOx.
Old 06-20-2008, 04:23 PM   #7
Beeterolds's Avatar
agreed however if you are in a pinch... run small gauge vacuum line over the oil line. to help with chaffing...
GM 8.5 3.73
Old 06-20-2008, 04:46 PM   #8
The Slacker
+1 on not using the line that comes with the gauges
I had a pressure line kink and oil squirting into your dash is NOT fun. The plastic line they give you is pure junk.
Old 06-20-2008, 06:29 PM   #9
fireant2178
fireant2178's Avatar
Send a message via Yahoo to fireant2178
+another. i had mines break and squirt oil under my hood. if i didn't have the id 10 t light i might have not caught it in time. btw the car was idling and i was reading something not looking at the guage.
Tony
442 N BLK
Old 06-20-2008, 10:56 PM   #10
The Stickman
It was for an electic guage. Had to get a special elbow fitting to just so the sending unit would fit. It is all together for the All GM Nationals tomorrow. Not completely like I wanted it but it works.
1992 Audi wagon
1996 Subaru wagon
