Thread Tools Rating: Thread Rating: 12 votes, 5.00 average.
Old 04-06-2008, 08:17 PM   #1
'77OmegaMan
Default 1965 Olds 330???
Whats up guys? I was just wanting to know if anyone knows anything about an Olds 330. Its bored 60 over and got performance parts in it...so i was told. Its spring break and time to replace my 231, is there anything someone could tell me to help me get a better fell on what i am putting in my car. Histroy, Facts, original specs...anything...
Thank for your help
Josh
Old 04-06-2008, 08:22 PM   #2
oldscsc
http://www.oldspower.com/vb/showthre...&highlight=330
I hope this helps.
'01 Silverado W/T, 4.8 / 4L60E / 3.42 / 305k
18" Z71 wheels on Bridgestone Dueler 265/65 AT's, Magnaflow muffler, Escalade cluster, Pioneer DEH-P3000IB head unit, Alpine SPS-600 door speakers, smoked factory tails, McGaughy's 2" drop shackles, black bowtie, 35% tinted windows, added factory receiver hitch, added chrome rear bumper
Future changes-- chrome or white grille, maybe an HD hood
Old 04-06-2008, 08:36 PM   #3
442_rocket
442_rocket's Avatar
I believe the '65 had the square bore intake and had the Rochester "4 - jet" carb that matched that intake. It should have a forged crank too.
1985 442
1980 Cutlass Salon (gone)
1976 Cutlass Supreme (gone)
1973 442 (long gone)
Old 04-06-2008, 08:52 PM   #4
So if that is true, it has been modified from its original factory configuration and there is no way to tell what its performance potential is without knowing what compression ratio and camshaft it has now.
Do you have any information at all about what has been done to it?
Old 04-06-2008, 08:52 PM   #5
'77OmegaMan
so generally is that a good motor, ok, or what is your opion...
Thanks
Old 04-06-2008, 08:54 PM   #6
'77OmegaMan
I was told that it has a "mild" cam with flat top pistons....let me see if i can recall the thread...
Old 04-06-2008, 08:56 PM   #7
'77OmegaMan
thread found:
http://www.oldspower.com/vb/showthre...light=Olds+330
Old 04-06-2008, 09:01 PM   #8
Thanks
Yes, it is a good engine. 330s are basically a slightly smaller bore 350, so whatever can be done to a 350 can be done to a 330. In fact, the 330 block can be overbored to standard 350 size and 350 pistons can be used. At that point you have a 350 with a forged steel crank and 45* Cam Bank Angle.
Old 04-06-2008, 09:15 PM   #9
'77OmegaMan
What about the heads. I have herd that they are nailheads...? Is the ture...something like they have small valves or something...
Old 04-06-2008, 09:19 PM   #10
I do not know hat you mean by "nailheads" but I assume it is not good? The 330s have very good heads, but they did use slightly smaller valves than the 350. I'm not sure what size they were, but if you are not happy with them they can be changed out for 350 sized valves. That and some porting would make them flow very well indeed.
Old 04-06-2008, 09:21 PM   #11
'77OmegaMan
thanks a lot...
Old 04-06-2008, 10:03 PM   #12
BILL DEMMER
BILL DEMMER's Avatar
Title: Parts Whore of the Apocalypse
the 330 is pretty much the same as a 350. advertised numbers are basically the same. they run and drive the same as the equivalent 350.
bill
'97 Buick LeSabre Limited(Dad's car)
'67 CUTLASS 4-DR. W/425 & S.P. THM400 (NAMED "ERNIE")(undergoing open heart surgery)
'83 H/O #1339(STILL IN PIECES)
'85 PONTIAC FIERO SE V-6 4-SPD. BOUGHT NEW
'92 CHEBBY DIS-ASTRO (GAS PIG)
'97 GEO METRO LSi (AVG. 36.5 MPG) winner of car vs. deer contest
Old 04-07-2008, 10:34 AM   #13
Run to Rund
I don't think you could get away with boring the 3.94" bore of a 330 to 4.057 of a 350.
Old 04-07-2008, 02:46 PM   #14
'77OmegaMan
ok guys i am thinkful for the help so far and have another question
has anyone tried to use G-body headers on a X-body car...like my Omega...or so on...
and is anyone impressed with some cheap mufflers they have bought that they would recommend or just stick with the 40 flowmasters???
Old 04-07-2008, 03:25 PM   #15
72CutSupreme
Title: Olds in the Blood
Hooker Aero Chambers FTW
Old 04-07-2008, 03:29 PM   #16
4Speeds4Ever
4Speeds4Ever's Avatar
Send a message via AIM to 4Speeds4Ever
I've never run G-body headers on an X-body or vice versa...but it's worth a shot...try it out and see if maybe just a lil' BFH love is all that's neded to get them to fit!
As for mufflers, DynoMax Super turbos flow VERY well (better than Flowmasters) and are around 40 bucks a pop. Thrush Turbos are okay, sound pretty old-school musclecarish, and are around 20 bucks apiece. I;ve used them both and have been very happy with both.
The 330 #4 heads (is that what you have?) are amongst the best of the small-block Olds heads, and can be machined to use the larger intake valve of the later #4A heads (from a 403). However, I believe the #4 exhaust valve is slightly larger than a #4A's, so no need to swap them over. Gently polish/port them, and you will have a set of great SBO heads!
-Crusty 1967 Cutlass Holiday Coupe, 350/350
-1984 Pontiac Grand Prix, 355, M20 Muncie, 8.5" rear w/3.73 posi, full Hotchkis suspension, 2 1/2" exhaust w/ Thrush Hush mufflers and cutouts
Old 04-07-2008, 03:58 PM   #17
philthy
"nail head" is a buick term
Old 04-07-2008, 05:57 PM   #18
'77OmegaMan
My heads are #2 not so good from what i have heard
Old 04-07-2008, 06:29 PM   #19
84 H/O
84 H/O's Avatar
Title: Turbo Tard
Send a message via Yahoo to 84 H/O
Nail head Buicks have teeny, tiny valves and that's where they get the nick name - from the size of the valve heads.
The G-body headers may fit the Omega subframe but in case they don't try 68-72 A body headers. I had a 73 Trans Am and after grenading a couple of 455 Pontiacs I stuck a 455 Olds in it with 403 T/A engine mounts and headers from a 69 442. They fit perfect. The subframe on your Omega is very similar to the 70 -81 F body I believe so it'll probably work.
Tony
1969 442 convert- 400, 200-4R, 3.73 posi, OAI, every option but cruise and power locks
87 Sunbird GT turbo convt - 13.61 @101, 260 whp/350 wtq. Not bad for only 2 liters huh? Same size as a coke bottle........
2009 Solstice GXP- quick and handles like it's on rails. I love these turbo 4 bangers!
2012 Ford FX4 Ecoboost V6, murdered out and ghetto cool
Old 04-07-2008, 06:48 PM   #20
BILL DEMMER
you should look at the thickness of a 330 block. the '64 330 (#1 block), i have will do it no problem. remarkably thick walls- .060" out of each wall isn't hardly going to "dent it". a slipper skirt piston might be required.
bill
Old 04-08-2008, 02:48 PM   #21
'77OmegaMan
Hey guys got my old engine out (231, 3.8) and am just making sure i have everything i need in place so on my links are some pictures of my intake i am missing some bolts and wanted to know if anyone knew if there where any sensors or anything that went in there...and my engine monunts don't line up and the standard ones from advance use studs instead of two mount holes. any sugestions on how to ge it to work...
Thanks Guys
Old 04-08-2008, 02:53 PM   #22
'77OmegaMan
Thanks Guys
Old 04-08-2008, 06:22 PM   #23
mike's88
mike's88's Avatar
I think when you say "nailhead", you may be refering to the 64' 330, which had shaft mounted rockers. In 65' olds went to the stud mounted rockers. The 64s are still a good head, just a little difficult to find valvetrain parts for that setup, I believe.
Old 04-08-2008, 08:18 PM   #24
4Speeds4Ever
The old Buick "nailhead" motors are SUPER easy to identify, with thier vertically-mounted valve covers. Super-cool looking motors...I had 300 (baby nailhead) in a '65 LeSabre, and a a pal had a Wildcat with the 401.
Old 04-08-2008, 08:58 PM   #25
'77OmegaMan
How eles do i get a pic to show up if the file size is to high to attach
