Old 10-24-2007, 11:28 AM   #1
kevin442
Default 1995 Olds Cutlass Supreme (3100 v6)
There is a common problem I've heard about with these cars. The security light stays on and from time to time I have issues with getting the car to crank.
It has dash lights, door buzzer, etc. In other words it's getting juice, but none to the starter. I know my connections are all good, including a new neutral safety switch. I've been told this is common and something about some wire connection having a short which causes the malfunction and triggers the security light on the dash. Can anyone tell me where this problem lies, so I can fix the short? It don't do it all the time, but from time to time it won't crank, but if I let it set for a bit and try again it works fine. However, the security light stays on, which leads me to believe this is my problem, but don't know where the wires are that I've heard about.
TIA
Old 10-24-2007, 02:18 PM   #2
kevin442
Originally Posted by MikeB View Post
Can't stress this enough, check ALL of your grounds.
Did you even read my post? It's not a ground.
Old 10-25-2007, 05:08 AM   #3
PITO'S 84
PITO'S 84's Avatar
What kind of pass lock is it? The one with the chip in the key?
________
LovelyWendie99
Old 10-25-2007, 03:42 PM   #4
kevin442
yep
Old 10-26-2007, 06:45 AM   #5
PITO'S 84
PITO'S 84's Avatar
Get a DVOM measure the resistance of the key chip and measure the resistance of the wire that conect to the IGN/CYL should be the same about +/- 10 write it down, go to radioshack and they should be able to help get u the resistors u need and solder them in between the wires and u bypass the the passlock or spend about 200.00$ and buy a new IGN/CYL. Also if you have a spare key that is fairly new try using that for awhile and see if that works, if it does happen, get a new key cut. MAKE SURE U HAVE VIN # AND POSSIBLE ID
________
CREAMY_SQUIRT
Old 10-26-2007, 10:03 AM   #6
Eightupman's Avatar
Title: Parts Haulin Mule
http://vats.likeabigdog.com/
This should help
John
