Old 07-09-2007, 02:26 PM   #1
gbledsoe
Title: Member
Question Chevy 350 Intermittent Lifter Tick
My daily driver, 1993 Chevy 1/2 Pickup with 190K miles on it has an interesting issue that seems to only occur when the weather outside is above 80 or so degrees -- basically summer time. Beginning last summer, I get a lifter ticking on the drivers side that is pretty bad and it robs the engine of quite abit of power. It started again this summer a couple of weeks ago. It never does it on initial startup on a 'cold' engine, but may just start after it warms up. Sometimes it'll just stop after awhile and the power is restored.
I'm assuming a lifter may be bad. Has anyone ever experienced something similar? As soon as I find time, I guess I'll need to remove the value cover when it's happening to determine with cylinder/valve and then proceed to remove the intake and investigate more.
Could it be a lifter going bad intermittently? If it was a valve spring, I'd assume it would happen all the time. I'm open for ideas.
Gary
My son's and my project.
71 Cutlass Supreme
Old 07-09-2007, 02:36 PM   #2
lostsheep
lostsheep's Avatar
Title: oldsmohaulic
Send a message via MSN to lostsheep
i would think a lifter has or is about to collapsed, go buy a nice cam and lifter set and be even happyer with it
1984-olds cutlass supreme-307/TH200r4/3.73,15.06@88.26mph 2.065 60ft, street/strip
1980-gmc high seirra-350/SM465/NP205/1ton axles/4x4, frame-off resto-mod
Old 07-09-2007, 04:25 PM   #3
Vern
Get your 455 Olds ready so that when the 3fity expires you can upgrade.
87 Olds 442, 10-1 509ci Cadillac, 800 Q-jet, Alum intake, Street portd heads, 230@50 528 lift cam, Headrs, 200-4r, 2800 stal lockup convrtr, Electric fans & in-tank fuel pump, AC, Factory oil tach temp gauges wrk, Fresh air Hurst hood & rear spoiler, 36mm hollow sway bar, 17mpg hwySold
87 Buick Grand National, 231ci Buick V6, TE-60 turbo, Stretch intrcooler, 42.5lb injectrs, 3" dwnpipe, 3000 stall lockup convrter, Meth/water injection, 22mpg, original ownr Both 2 run 11.8 113+ on pumpgas
Old 07-09-2007, 05:47 PM   #4
TylerW
TylerW's Avatar
Title: Truth Talker
Photos: 13  Users Photo Gallery
Send a message via AIM to TylerW Send a message via Yahoo to TylerW
Haha..I had a 93 Silverado that did that exact same thing. Mine would do it after a warm start....sometimes once every 6 months, sometimes 3 times a week. It happened from 140k till 215k when I sold it and never got worse. I wouldn't worry too much about it. The power loss is probably the knock sensor picking it up and retarding the timing.
It's likely a lifter that's failing to pump up with oil...it may have some dirt in it. Pretty much with 190K you just live with it until that engine dies..which may be a while.
1971 Plymouth Valiant
1973 Dodge Dart Sport
1987 Pontiac Grand Prix LE
Old 07-09-2007, 06:37 PM   #5
Beeterolds's Avatar
Title: Armed and Hammered
Send a message via AIM to Beeterolds Send a message via MSN to Beeterolds Send a message via Yahoo to Beeterolds
flush the motor out im willin to bet its ticking because of excessive sludge buildup
