Thread Tools Rating: Thread Rating: 8 votes, 5.00 average.
Old 12-29-2006, 08:35 PM   #1
1970cuttass
Default Rear End Gear Ratio Suggestions
I am running a 1970 Cutlass S with a 350, .030 over, brand new performance intake and exhaust, 750 cfm edelbrock, new TH350 with shift kit and 1500 stall. Im pretty sure stock its 2.73 or something like that and it really needs something new to wake it up. I guess im looking for something street/strip that really gets off the line. A friend suggested 3.73 or higher, i was wondering what this oldsmobile community thinks. Thanks.
Old 12-29-2006, 09:23 PM   #2
Status: Online
I'm using a 3.73, but that came stock. I suggest 3.42 because it will still feel like adding 50hp but give decent hiway rpm.
For street/strip I would also suggest dumping the edelbrock. Its not that great, a holley or a quadrajet would be the best, quadrajet being the best overall. I would suggest a Preformer RPM intake amd I would add a 2000+ stall converter. What type of exhaust did you go with? Did you get headers too, if not get them, they make a huge difference. Did you upgrade from the points distributer yet?
Old 12-29-2006, 10:10 PM   #3
1970cuttass
I actually do have a performer rpm intake, i have hooker headers back to series 40 flowmaster. I also did go to the HEI distributor. I forgot to add i have a lunati braket master II cam. Thank you for the advice.
Old 12-29-2006, 10:25 PM   #4
Status: Online
I ran that cam before, I would severly suggest a 2400-2500 stall converter and 3.42-3.73 rear gear to get it running at its best. That cam is pretty lumpy and quadrajet would make it run better at part throttle and cruising and still maintain a great top end. It would be a huge improvement over that edelbrock. My edelbrock did not like that cam at all, it ran good with my holley though
Old 12-30-2006, 12:33 AM   #5
lostsheep
lostsheep's Avatar
Title: oldsmohaulic
Send a message via MSN to lostsheep
i would go for the 3:42
1984-olds cutlass supreme-307/TH200r4/3.73,15.06@88.26mph 2.065 60ft, street/strip
1980-gmc high seirra-350/SM465/NP205/1ton axles/4x4, frame-off resto-mod
Old 12-30-2006, 01:10 AM   #6
big man
big man's Avatar
Damn I have the exact same setup... 70 engine 355 w/bracket master 2 cam, but I have a 3000 stall, not a daily driver (and I don't care) and I plan on putting 3.90's in my rear..... I just hope my compressions good. I think we will be pleased if the compression is right. Should be a good combo..... unless Captjim says otherwise
Old 12-30-2006, 03:34 AM   #7
1970cuttass
Mines more of a daily driver except for in the winter. I want to be able to drive it on the highway without winding too high.
Old 12-30-2006, 06:43 AM   #8
big man
big man's Avatar
4 speed should solve that.
Old 12-30-2006, 12:04 PM   #9
1970cuttass
What do yall think about replacing the gears in my stock rear end? or should I go for a new housing, n axles and the whole deal?
Old 12-30-2006, 03:40 PM   #11
1970cuttass
I bought the engine rebuilt so i forget what pistons it has, i doubt they are anything special.
Old 12-30-2006, 04:08 PM   #12
If you have the original O-type 12 bolt then your gear ratio choices are very limited. Richmond Gear sells new gear sets in 3.42, 3.90 and 4.10 ratios only:
http://www.richmondgear.com/01pdfs/page11.pdf
Along with the gears you will need a different series carrier as the new gear sets are made to fit the original 3.08-3.23 ratio carrier.
Old 12-30-2006, 07:07 PM   #14
1970cuttass
Hmm.. the guy who had the engine rebuilt actually said it is supposed to make about a 10:1 compression, but i will definately look into it. What do you think about a used ford 9 inch with 3.50 ratio?
Old 12-30-2006, 11:39 PM   #15
My engine was rebuilt with cast "factory replacement 10.25:1 pistons" and I calculate I actually have around 8.5:1.
Listen to what captjim is saying - he's been there and done that.
Old 12-31-2006, 01:52 PM   #16
big man
big man's Avatar
Originally Posted by captjim View Post
Here we go again. If cast replacement pistons were used, your compression ratio is not enough for that cam. That cam likes 10.0 or so, you are probably closer to 8 to 1. Do a cranking compression test.
How's that test done? Does the motor have to be out of the car?
Old 12-31-2006, 10:31 PM   #18
bigdan
I had a 350 cutlass 4 barrel it had factory 10.0 to 1 CR with 3:42 it will give you a nice set up street -highway
you dont have overdrive so 3:42 is good compromise
i would install a 2200- stall torque converter you will be surpise how much difference off the line your car will act ...specially with that cam
I had a 1970 W-30 with 3:91 gears : good for strip and short trips on the road forget the highway olds dont like sustained high rpm
Dan
Old 01-11-2007, 05:42 PM   #19
7-D442
7-D442's Avatar
Title: Registered User
Greg@ Supercars Unlimited should have everything you need in your area! 3:42's are a very good all around gear
Old 01-13-2007, 11:13 AM   #20
tommy
I put 3.42 in my car and they seem alright. Run about 2800 rpm at 60 mph with 28" tall tires. Would be nice to get the rpms lower but would also be nicer to have deeper gears. So the 3.42's were a good compromise. I eventually want to get an overdrive and deeper gears since this is my daily driver but the cost is a little high for me right now. 3.42 would probly be good for you too.
Old 01-13-2007, 01:35 PM   #21
freak007
freak007's Avatar
Send a message via MSN to freak007 Send a message via Yahoo to freak007
Which BMII cam did you use? Lunati makes 2 of them... a 214/224, and a 224/234... You may need a bigger stall... For rear gears I would run 3.23 or 3.43.
A 4 speed and an auto will have a cruise RPM within 10% of each other
I may not agree with what you say, but to the death I will defend your right to say it - François-Marie Arouet AKA "Voltaire"
OldsPower.com © 2012 Herald/Rothe
