Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Old 03-26-2006, 07:04 PM   #1
slowcord
slowcord's Avatar
Default A/C bracket
quick q? is the sbo a/c braket the same for all years, i still have the compressor from the 69 engine, and im wondering if i should salvage the bracket or find one specific to the g-body?
1981 Cutlass Supreme Brougham
455/2004r/3.42
Current Rides:
89 Olds Toronado Trofeo
92 Nissan NX2000
Old 03-26-2006, 11:08 PM   #2
slowcord
slowcord's Avatar
no one know, i guess ill just take it off then, and save it until then, and chuck the a/c compressor.
455/2004r/3.42
Current Rides:
92 Nissan NX2000
Old 03-27-2006, 12:18 AM   #3
1985Cutlass455
1985Cutlass455's Avatar
Photos: 22  Users Photo Gallery
well, no they arent all the same. G bodies used the smaller pancake compressors, and the 69 would have used the long A6 compressor. There are a ton of 307 powered cars in the junkyard that you can salvage a good matching set of brackets and pulleys from if you need to. I guess it depends which style of compressor you want to use.
1985 Cutlass Supreme Brougham
1971 455 .030
9.75-1 CR
'C' Heads
Edelbrock Performer Intake
Lunati Harold cam 226-233 @ .050
900 CFM TBI Holley Commander Fuel Injection
TH200-4R From Monte SS
2800 Stall "D5" Converter
GN 8.5 3.73 POSI Rear
36MM TA Sway Bar
True Dual X Pipe Exhaust W-Z Manifolds
Black Interior W/ Lightning Rods
Current Status: Bought a house, car has sat in garage for over 2 years now :O whoops
