OldsPower.com
Go Back   OldsPower.com > Discussion > Engine/Transmission/Driveability
Register Forums Gallery Support Us! FAQ Mark Forums Read
Help Support OldsPower.com
Reply
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average.
Old 07-27-2010, 06:34 PM   #1
BlacknGold442
BlacknGold442's Avatar
Title: Proud Olds Owner
Status: Offline
Default olds 403 timing
what should i set my timing degree at on my olds 403 with 350 7A heads
__________________
Old 07-27-2010, 06:35 PM   #2
olds307 and 403
olds307 and 403's Avatar
Title: I Have an Olds Life
Status: Offline
Photos: 10  Users Photo Gallery
Default Re: olds 403 timing
Try 20 at idle to start.
__________________
1988 CSC, Ported #6, 9.5 to 1 Olds 350 .483/.508, 2004R, 3.42
1994 c***y 4x4 Olds 350/454 TBI, rebuilt 4L60E, 3.73 gov lock
2010 Challenger SE, Stone White, leather, 18" wheels
2000 Dodge Dakota Sport Club Cab 4x4 AEM filter,air box mod, Dynomax muffler, Accel coil,3.9 v6, auto, 3.92 no slip
Old 07-27-2010, 11:01 PM   #3
marcar1993
marcar1993's Avatar
Title: I HAVE no Money
Status: Offline
Photos:Users Photo Gallery
That's what I run mine at.
__________________
-Martin
87 Olds Cutlass- 1970 Olds 350, t56, 3.42 posi
My Old 403 Build Here
72 Plymouth Satellite 9 pass. wgn.- grandpa bought it new
93 Dodge Dakota- plow truck
01 Ram 2500 Cummins 6spd- Daily Driver
Old 07-28-2010, 03:26 AM   #4
rdltmc3
rdltmc3's Avatar
Status: Offline
Send a message via Yahoo to rdltmc3
I'm running at 18*
__________________
Faster, faster, faster, until the thrill of speed overcomes the fear of death~Hunter S. Thompson
Nick
Old 07-28-2010, 07:47 AM   #5
Anubis
Anubis's Avatar
Status: Offline
I can get away with 21 if I can keep it cool. If it get's above 200 F, it will spark knock. I'm running #5's at 9.4 : 1 static
Old 07-28-2010, 12:04 PM   #6
svnt442
svnt442's Avatar
Title: Oldsmobile "Numbskull"
Status: Offline
Send a message via Yahoo to svnt442
Quote:
It's not set at idle. You're supposed to set the base timing to 20 @ 1100 rpm.
__________________
Randy
75 Cutlass S 260 - Junked
76 Cutlass Salon - Wrecked
75 Cutlass - parts car
80 Cutlass Supreme - Sold
70 Cutlass S Post - stripped & junked
72 Cutlass Supreme - stripped & junked
70 442 SOLD..and REPURCHASED!..wrecked
Old 07-28-2010, 12:37 PM   #7
71CutlassConvertible
Title: Olds Gearhead
Status: Offline
With the vacuum advance line disconnected and plugged.
__________________
Daily Driver - 355 cid, UltraDyne .485/.485, 217/221 cam, Performer RPM intake, 750 cfm QuadraJet, HEI, Heddman Headers, TH350/Hughes 2500 stall, 3.23 limited slip, BFG 245-60-14s on SSII wheels
Old 07-28-2010, 01:35 PM   #8
IIIQuaZIII
IIIQuaZIII's Avatar
Title: Master of Disaster
Status: Offline
Photos: 12  Users Photo Gallery
Send a message via AIM to IIIQuaZIII Send a message via Yahoo to IIIQuaZIII
I set most stock engines 20* at idle. They all run fine. Olds motors love timing.
__________________
If a company advertises something as "indestructible", Trust me, I'm the guy you want testing it.
"Warning: Not to be used as a toy!" -The mark of all great toys.
iiiquaziii@yahoo.com, iiiquaziii on AIM/iiiquaziii on Yahoo messenger and gmail and gtalk. http://www.facebook.com/#!/profile.p...00001623773081 in facebook.
Old 07-28-2010, 01:51 PM   #9
olds307 and 403
Status: Offline
Agreed, Olds engines, especially low compression motors like a lot of timing. I realize the 1100 thing but think that is a stupid way to set it.I have seen anywhere from 13 to 22 setting at either 1100 or 2200, I believe. Actually set your base timing to wherever you need to get 34-38 total. My car ran faster at 36 total and that was 15 base at idle. That varies from distributor to distributor too.
__________________
Old 07-28-2010, 03:59 PM   #10
rdltmc3
rdltmc3's Avatar
Status: Offline
Ok what's the difference between base and idle timing?
__________________
Nick
Old 07-28-2010, 04:23 PM   #11
IIIQuaZIII
IIIQuaZIII's Avatar
Status: Offline
Quote:
Base timing basically is idle timing with the vacuum disconnected. Total timing, includes mechanical advance at high RPMS/WOT, and then there is also the addition of vacuum advance at part throttle.
__________________
Reply
Thread Tools
Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
A vBSkinworks Design
Powered by vBulletin® Version 3.6.3
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
OldsPower.com 2012 Herald/Rothe
