HRPartsNStuff
Old 06-29-2009, 09:10 PM   #1
TheBigO
TheBigO's Avatar
Default Adjusting Shift Points?
My question is-Can you adjust the shift points on a TH-400 trans. If so....how? Your answers is highly appreciated
My transmission is a BOP TH-400 automatic with a 2,200 rpm stall, no shift kit.
Turbocharged 455 BBO
http://www.streetfire.net/video/turb...nk_1852754.htm
Old 06-29-2009, 10:39 PM   #2
jd79ta
jd79ta's Avatar
Default Re: Adjusting Shift Points?
A cheap and simple way to make the car rev more before it shifts, if that's what your after. What I did on my gmc, that had TH400, I bought a new "modulator" I think that's what it's called someone can correct me, that was adjustable, some are adjustable stock. Just pull the little vacum line off the trans and turn the tiny screw in for higher rev's out for earlier shifts. You just need a small slotted screw driver. I believe you can replace the spring behind the mod. to adjust the shifts as well, but I didn't bother with that even with the shift kit I installed, it came with springs, and I left them out which is how it already was anyay.
Jamie
(Burnout)---http://www.youtube.com/watch?v=e3YLP0NXzSY
Old 06-30-2009, 04:03 AM   #3
mkube396
mkube396's Avatar
Title: ^^^^^^
Send a message via AIM to mkube396
get a adjustable modulator
P.S your runing a turbo so i dont know how you would get vac to the trans?
some times i do feel like i have a crayon in the brain
1981 Chevy monte carlo + Chevy 396 = crazy FUN! 8.616 @ 82.38 Mph in the 8th
like uncle ben says.... "With great power comes great responsibility" Drive Safe
don't be a REV Mechanic you dont need to rev it to the moon to fix it.
2003 impala the driver
1981 Monte Carlo
1991 Oldsmobile Calais "RIP" 130K
1989 Oldsmobile Cutlass Supreme "RIP" 140K
Old 06-30-2009, 05:42 AM   #4
matt69cutlass
Status: Online
You can make small changes with a adjustable modulator (2-4 mph) if you need to move the shift points more than that you'll have to change the govenor.
69 Cutlass, 455/ Edelbrock heads,11.51 @114 grocery getter,gotta get the ice cream home before it melts!
87 Cutlass 455/2004r, all the leftover parts from the 69, 2 time Power Tour car
I tell my wife if I didnt do the car thing Id take up drinking! Everyone has to have a hobby!
Old 06-30-2009, 06:14 AM   #5
jd79ta
jd79ta's Avatar
Not sure how much difference in mph it makes but as for the rpm, it's quite a difference, I probably added esily 500rpm more to the shift points at light acceleration could of went more but I settled it at around 2000rpm.
I actually did the same thing with my T/A, I set it to shift around 1800, it already had an adjustable one in it, I just had to turn the screw.
Jamie
Old 06-30-2009, 07:10 AM   #6
mkube396
mkube396's Avatar
Title: ^^^^^^
govenor only controls the Trans shifting at WOT not part.
1981 Monte Carlo
Old 06-30-2009, 10:17 AM   #7
TheBigO
TheBigO's Avatar
You just read my mind! Yes! I want my engine to rev more before it shifts.......and I didn't know there was a adjustable modulator for it....where can I buy one for a BOP TH-400.
Old 06-30-2009, 10:38 AM   #8
TheBigO
TheBigO's Avatar
Simply adjust the screw inside the vacuum nipple for more or less diaphragm preload??? counter clockwise or clockwise to rev more before shifting......I am not sure if mine is adjustable if its a stock one...my trans is a remenfactured TH-400 I bought from advance autoparts 3 years ago....the only mod was the deep derale trans pan and filter magnet
Old 06-30-2009, 03:40 PM   #9
425 Racer
They make a kit for the govenor to shift at higher rpms (B&M I think) with springs and weights.
Nick
A small block with big block attitude!!
380 cubes (+ 45)
"Many messages are hidden because olds school is on my ignore list."
Old 06-30-2009, 06:13 PM   #10
jd79ta
jd79ta's Avatar
You turn CW "in", to get more rev, CCW "out", to shift sooner, doesn't matter if its BOP or chevy, they'll work, my TH400 didn't have one stock, it cost me like $20 about 5 years ago, if IIRC. My TH350 in the T/A was an adjustable already.
Jamie
Old 06-30-2009, 09:13 PM   #11
TheBigO
TheBigO's Avatar
How hard is it too remove the stock valve modulator and replace it with a adjustable one?
Old 06-30-2009, 10:57 PM   #12
jd79ta
jd79ta's Avatar
The modulator and the govener, are two different things, the mod, very easy, it's set up like a distributer, just shoved in and there's a hold down tab, very easy to remove/replace. The gov. is different, not 100% sure about the TH400, but on the 350, it's a cover with a clip over it, but the cover is usually pretty well stuck on there, and it's a pain to get on, unless you have the tranny out of the car then you can just tap it in, I tried to do mine on the car, and had a hard time getting the cover back on, I even put it in the freezer too hopefully shrik it a bit, but still had to tap it on. Aside from the cover, the govener is really easy itself to take out and put it, and the springs can be replaced without taking it apart completely.
Jamie
Old 07-01-2009, 01:02 AM   #13
RocketV8
RocketV8's Avatar
TheBigO - what are your current shift points? At part throttle and WOT.
No man with a good car needs to be justified
1965 Cutlass
Original 330 High Comp Engine
TH350, Hughes 2500 Converter
Edelbrock Performer RPM, Holley 1850
Recurved Distributor, Pertronix Ignitor
Hooker Headers, Cherry Bomb Glasspacks
8.2" 10-bolt, Richmond Gear 3.55, Auburn Posi
Old 07-01-2009, 04:32 AM   #14
425 Racer
Sorry but the modulator will be a better deal for what you want to do.
Nick
380 cubes (+ 45)
Old 07-01-2009, 04:47 AM   #15
RocketV8
RocketV8's Avatar
The governor directs fluid flow to the shift valve(s) based on output shaft speed (road speed). The modulator directs fluid flow to the shift valve(s) based on manifold vacuum (engine load) but to the opposite side of it, thus delaying the gear shift. The governor definitely plays a role in shift points both at WOT and part throttle.
1965 Cutlass
Old 07-01-2009, 09:42 PM   #16
TheBigO
TheBigO's Avatar
I just found out that my modulator is adjustable....I removed the vaccum hose...... inserted a thin flat head screw driver.....and turn clockwise.....it felt like I was turning a small screw driver....I only turn it only 1/4 for now....I will take for a spin in the morning too see how the shifting feels...As to answer your question....my shifting feels weak....I mean...I don't feel a cripy shift....I would like too have more cripy shift....though of pouring in F-type fluid in my next transmission filter change....for a more crisper shift.
The whole reason for this.....I would like to have my engine rev a little more before it shifts....I notice my turbocharger spools alot faster.....at 2,500rpms instead at 3,100 rpms.....I am not sure why?? But it does for some reason.
Old 07-01-2009, 10:05 PM   #17
jd79ta
jd79ta's Avatar
I just found out that my modulator is adjustable....I removed the vaccum hose...... inserted a thin flat head screw driver.....and turn clockwise.....it felt like I was turning a small screw driver....I only turn it only 1/4 for now....I will take for a spin in the morning too see how the shifting feels....
You gotta turn a quite a bit to get a real difference, you might need to go 3-4 turns (complete turns), depending on how much change you want. I know I went a couple turns.
Jamie
Old 07-02-2009, 04:37 AM   #18
matt69cutlass
Status: Online
I didnt notice the engine was turbocharged, that changes things. You cant adjust the modulator with a turbo, the reason being the modulator reads VACUUM. Under boost the trans thinks your at WOT. Your going to need a mechanical modulator, I know B&M use to make one. If you cant find one your other option is a manual valve body. I can provide a kit to convert your valve body if your interested in going that route.
Old 07-02-2009, 07:29 AM   #19
TheBigO
TheBigO's Avatar
So you are saying that my TH-400 will go into 3rd gear fast? That intersting how come STS turbocharger, HP turbocharger, Procharger Supercharger, Vortech supercharger, and Paxton Supercharger companys don't meantion this too to there custmers when they are selling there basic 5-6 psi kits on there older engines with automatics? Any who....here a link of a vid for my olds
http://videos.streetfire.net/video/T...psi_649505.htm
Old 07-02-2009, 08:02 AM   #20
matt69cutlass
Status: Online
Do you have access to a hand held vaccum pump? If so try this. Appy 10 inches of vaccum to the modulator, see how it shifts. Apply 5 inches, test drive,try 15 test drive and so on. Hopefully you can see a pattern develope,more vaccum=early shifts, lower vacuum=later shifts. Im not sure why the turbo manufacuters dont mention trans modifications, maybe if you talk to them they will have another solution. Anyway Im pretty sure a TH 400 trans modulator wont work correctly with a turbocharge engine. As soon as the engine starts to build boost the trans will think your at WOT. Hope that helps.
